Front end alignment
Front end alignment
Got an issue with my front end, the handlebars and forks point straight ahead as they should. The head bearings are adjusted propery, and the fork oils is good and the fork measurements from the top of the cuff to the bottom of the tree are identical...... I'm starting to think my front wheel bearings are ****.
When I ride, I notice the right fork looks slightly lower than the left, could old bearings contribute to this problem??????
Well each fork tube has it's own spring so maybe one is just sacked out more than the other. With everything that ties it together I would think not but who knows. Also the spacer and rebound spring within the fork plus the amount of fluid in each fork may have a bearing on ride height. Lots of things to drive a guy nuts.
Mississippi Bagger
01-24-2008 03:30 AM
