Throttle Cable issue - Burly - Gangster 16"
I purchased 16" Carlini Gansters and the accompanying cable kit from Burly they sell, along with the extensions - I purchased new handgrips from Hd (chrome and rubber - part number was one HD recommended) Got everything tore down, and have noticed that my throttle cable seems to be 1/2" to an 1" to long. Idle cable is fine, clutch, brake, bars..everything cept the throttle..any idea what I might be missing?
I called Carlini and they said that sounded odd and to take a photo, which I will - just wanted to check with the folks here as well.
If it's just 1/2 inch too long...that is easy to line up when running and fix it to make it look perfect. One thing to consider with throttle and idle cables is turning your bars. You don't want it too tight and when you turn your bars to left it gets way too tight and pulls on the cables in the carb area. Make sure you are checking this stuff correctly. If you have the bars turned all the way to the right then it will show more slack because they will have more play when turned all the way that way. FYI
