Cables for 18" apes on a 2001 heritage springer
08-23-2012, 11:06 AM
any one have the cable lengths required or suggestions on who to contact.
Throttle
Idler
Brake
Clutch
Thanks upfront for the help
08-23-2012, 01:05 PM
Quote:
Originally Posted by
HARLEYTIMFLSTSI
Throttle
Idler
Brake
Clutch
Call Chucky at LA Choppers.
I did 16's on mine, with 1.5" risers (new top tree to run regular risers) and did these measurements:
Throttle/idle: 31", or +9
Clutch: +9
Brake: +7
Bear in mind your bars are 2" taller, and you have taller risers if you are running the stock springer risers.
Also, once you have the right lengths, you can call Barnett and order from them. Then you can choose the platinum finish, for extra shiny cables!
08-23-2012, 02:14 PM
appreciate the info.
I found the Magnum BYO Cables, and may go that route after a little research. You know of any one who has used these? Seems pretty simple to do.
08-23-2012, 02:16 PM
I've got Magnum's on my Street Glide. I bought built cables, not BYO's.
Can't comment on the BYO's...someone else may be able to chime in about those.
08-23-2012, 03:00 PM
2003 heritage with 14's.... I did +6 on all and they fit perfect with routing cables clean with wild one chubby bars.
08-23-2012, 03:11 PM
08-23-2012, 04:28 PM
I just called Hill Country Customs and told them which bars i was using and they hooked me up with a complete set of stainless braided cables for around 200 bucks. They were exactly what i needed and the cables are great quality.
08-24-2012, 02:45 PM
Rok n Roll
Thanks man. Spoke with Brian and all cables will ship Tuesday for $225.00 delivered.
DynaJ
01-05-2012 09:38 PM
suntadz
07-29-2011 07:03 PM
rowdy82
Softail Parts
05-05-2010 02:00 PM
murlsquirl
01-25-2010 10:47 AM
twisted125
12-21-2009 05:25 PM
