How Centered Are Your Samson Duals?
I just might have been one of the lucky guys. Mine installed exactly centered.
Now, I did have to spend some time to make sure the tips were exactly the same height from the ground. That took a friend holding the left pipe upward while I tightened the rearmost pipe clamp and the fishtail mounting bolts.
my samson fishys came with a bent bracket. it was warped, kind o twisted....i sent it back to them and the rep confirmed it was bad. the new one she sent me was also a little bit off. so what i did was go to ole faithful (The Home Depot) and bought some washers. i ended up putting 2 washers inbetween one of the mounting bolts. (between rear bracket hole and frame). this addition brought the pipe in and trued it up nice.
simple fix.
but ....im still wondering why. maybe they had a bad batch of mounting brackets?
simple fix.
Lonny Morgan
04-29-2015 06:43 AM
