I am running V&H long Shots on a 95 heritage softail and want to add a Arlen Ness bigg sucker and need to rejet the carb but with what? Cant find any info. any help would be apreciated. Thanks.
what size engine if its tc88 with the cv carb throw in a #46 jet and shim the needle with 1 #4 washer then should be around 2.5 turns out on the mixture screw that will get you real close.
I have a 48 pilot and 180 main on my 1996 Heritage. I'm gonna try a 46 pilot jet soon as I'm running a little rich and getting 40-42 mpg solo, and 38mpg 2 up and loaded. Try those and you should be close. I kinda guessed toward the rich side when I put in the EV 27 and had the heads done.
This is very interesting because the a/c is on a carb it ain't designed for. I mean my s&s is simple enough because the directions are great, the videos are great and they are just great in general.
What is your carb model?
