Brake light stays on.
Hey y'all I have a 97 Fatboy turn signal on the left does not work but the brake light and tail light stays on as well when you're going down the road the lights will just shut off and then end up coming back on does anybody know what's up would appr
It's probably the brake light switch at the brake lever, there is a little post in there you can hardly see that can get stuck causing the brake light to stay on.
I have got to get to work, maybe someone else can chime in on how to clean or replace, not as easy as you would hope.
The correct answer is you need the master cylinder rebuilt. You're supposed to flush the brake system out yearly but it's probably the most neglected item on the bike. That WD40 is only a quick fix. If you're handy around the shop you can do it, just grab a kit at the local indy for $20. The other inexpensive route would be pull the master cyclinder and head to the local indy for a rebuild, 20 mins later and probably $30-40. Last would be the friggin stealer
Do you or ANYONE have any clue what this is and where it goes? There are no numbers, letters, or anything on it which is so weird.
Any help would be so much appreciated!!
