Fuel Pack Relocation Help
I have a 2008 Night train and the power commander is underneath the stock bad lander seat. The problem is any seat I have tried to get that has back support wont work because the fuel back is in the way. Has anyone relocated it and if so have some advice or instruction? Thanks in advance
I had the same issue with the connector (as have several other posters). The best solution I've seen on this forum, especially if you want the flexibility of changing seats at will, was replacing the battery with a shorter one and allowing the connectors to occupy the space created above the battery. I'll need to have a look though my pms to find the battery part number and OEM.
