1993 ignition coil wiring...red wire location
I was working on my 1993 Softail and removed the coil cover and set it aside to do some work. When i turned around and looked at the coil, i noticed the red wire just hanging there. There are no terminals missing any wires. The only thing it can reach is the cover screw. I assume it must have been attached to ground using the screw that holds on the cover. But then I am thinking that red is typically positive. I couldn't find the wiring diagram on line. I figure someone here knows where it goes. Thanks for any assistance in this.
Art
Art
