Cylinder heads
Cylinder heads
Hello All,
I dinged up the exhaust stud port on my rear head (i know sad) so now I need to replace the head. I see lots of softail heads on ebay, but not any that share the same part number as mine (17179-06). The most available heads are 17193-06. Will this work on my bike?
My wheels are 09 Rocker C.
Thanks!
Thanks!
that sounds a little more fatal there, I believe that the 06 heads were smaller valves than the later ones that is why you see so many of them, do you think yours is repairable once the head is off? the stud can be removed and then weld the head and tp in a new stud. but by then you may be at the price of as used head. you want the later model head with the larger valves
