Turn Signals dont flash but 4 ways do.
On my 93 Heritage. I've been going in circles here. First my right turn signal wouldn't flash it would just light up. Changed front bulb because the running light filiment was burnt. Next the left signal wont flash unless its sitting at idle or engine off. All bulbs are good. Anything above idle, it just stays bright steady. Now I have both turnsignals lighting steady bright. Neither flash when selected each side, but if I use 4 ways they both work at any speed. Could the flasher be going out? Why would 4 ways flash, but not left or right by themselves?
Those are self resetting circuit breakers. It's probably the TSM. It's on the top of the frame rail, under the speedometer.
Thanks, I will check tomorrow on my day off and post a photo of the location to help anyone else out on this.
That sounds like your wiring/sockets/bulbs are all good...replace your TSM with one of these.
https://www.denniskirk.com/H21098.sk...ad=45712965997
Mark M (05-13-2016)
