Vee Rubber White Wall Nightmare
Old 07-31-2012, 04:33 AM
Redhill Phil's Avatar
Redhill Phil
Redhill Phil is offline
We have a mean degreaser at work that re whitens the writing on the ute tyres.
Old 07-31-2012, 04:38 AM
dlite001's Avatar
dlite001
dlite001 is offline
2nd Gear
Thanks for the feedback!
Old 07-31-2012, 05:02 AM
aaamax's Avatar
aaamax
aaamax is offline
I'm lovin' me some yellow walls. IT's all how you look at it.
I'm joking.
good luck with the exterior wall paint (latex).
Old 07-31-2012, 06:56 AM
Motown Strag's Avatar
Motown Strag
Motown Strag is offline
You can buy ww paint, google it. My vee if fairly white but i dont clean it much, anything from thailand is going to have spotty and batch quality issues. The real question is why are the real companies leaving us hanging? Not hard to put a ww on an existing tire in thier line up.
Old 07-31-2012, 09:15 AM
Benway's Avatar
Benway
Benway is offline
Interesting blurb about whitewalls:
Tires were introduced around 1902, and they were made using white rubber. Cars like the 1904 Auburn had been fitted with pure white tires on the front and back. After a few years of use, it was obvious a change was needed. The white rubber tires had extremely poor traction, and in the rain, they were virtually useless. Then the manufacturers started adding carbon black to the white rubber. However, the carbon black was more expensive than the white rubber mixture, so they left the sidewalls white and just used carbon black on the treads. After all, the treads were the only part of the tire that came in contact with the road surface, so the decision was cost effective. That started a variety of tire models created with different amounts of the white walls showing. What was at first an economic feature then became an aesthetic one.
Old 07-31-2012, 02:06 PM
ssrgeoff's Avatar
ssrgeoff
ssrgeoff is offline
Yep DB is no longer able to offer the WWW on motorcycle tires. Hopefully someone steps up to the plate or on the next tire change I may need to shelf the 3.5" for a 3" wheel.
Old 07-31-2012, 02:49 PM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
I'm sure its been suggested at some point but have you tried westley's bleach white and a scrub brush?
Old 07-31-2012, 03:16 PM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
Westley's and a brush are great on a nice white white wall but these Vee's are sort of yellowish or brownish. I have used the kiwi shoe polish that comes with the sponge tip on these Vee's in the past. I put some painters tape around the black portion on the edge of the tire and go to town. It is what it is as there is no mass produced WWW in this size and I don't see it happening anytime soon.
Old 07-31-2012, 04:11 PM
thelawnmowerman's Avatar
thelawnmowerman
thelawnmowerman is offline
Real pissed at this news, I would not have gone with a 21 front if I'd have known this was going to be a problem, hopefull someone will come up with something.
Old 07-31-2012, 04:15 PM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
It's not that there is a problem, it's more like it is extremely time consuming and it is his side business. The first job has to be done first. I was also told that could be possible legal issues with grinding off the writing that comes on the tire which has to be done in order tof lay the white wall.
Quick Reply: Vee Rubber White Wall Nightmare
