Fatboy Lo axle nut torque specs
Old 04-28-2013 | 11:05 AM
Scuba10jdl's Avatar
Scuba10jdl
Originally Posted by Rakthi
For 2007 rear axle: 60-65 ft/lbs -- 81.3 - 88.1 Nm
For 2009 - xxxx rear axle: 95-105 ft/lbs -- 128.1 - 142.4 Nm
Guess the change in bearing/axle size cause the change in torque values
They went from a solid axle to a hollow one, which is the reason for the torque value change.
Old 04-28-2013 | 11:28 AM
cjbmustang's Avatar
cjbmustang
I remember seeing people make pieces out of coat hangers. you put one end into the frame and measure to the center of the axle. then you do the same for the other side. you need to get the belt tension correct also. you can buy a gauge. i think with my sportster a common method was twisting the belt a certain amount. it's been a while. trying looking on google or youtube
Old 04-28-2013 | 10:42 PM
Rakthi's Avatar
Rakthi
Thanks for clearing that up! Learn something new every time I visit the forum.
Old 05-02-2013 | 06:23 PM
snowman fatboy 2007's Avatar
snowman fatboy 2007
6th Gear
Thanks liquidr1
i removed the wheel today set my torque wrench low and kept turning it up till the nut turned on the axle came lose at 110 ft/lbs its a 3/4 axle so 60-65 ft/lbs is right ? i guess harley tech over tighten it last time if 60-65 ft/lbs is right .
GittinThere
10-03-2022 03:53 PM
nail bender
03-06-2010 08:40 AM
Puttnutt24
04-25-2009 01:17 PM
robertj74
04-10-2008 05:05 PM
Nitram
09-15-2007 11:34 AM
Quick Reply: Fatboy Lo axle nut torque specs
