Need Help with taking the front wheel off
I have the manual for the Softail but for some reason, I can't find a way to take off that front rim from the forks. Either I am skipping the rocker section or they don't have the Rocker material.
It just shows a big nut on where the hub goes.
However on the Rocker, it has a indented hex screw on both sides and wondering how to take that off.
There are 2 5mm Hex nut only on the right side fork on the bottom.
I took that off but nothing.
I am for sure that I need to be loosening the Big Hex Screw on the Axle am I correct?
If so, what would be the size for that???
Just got a fender and eagerly wanting to put it on but without taking off the tire, I just can't access the torx screws that holds the fender.
Any help would be appreciated!
Yes, the 2 bolts for the brakes definitely came off before anything.
The bolts at the bottom of the fork is more like 5mm Hex for the Rocker C.
At the same time, the bolt or Axle nut that I have in question is this on the picture.
I really don't know what to make out of this.
It just looks like a gigantic HEX head.
fireb
check out my post on progressive here
https://www.hdforums.com/forum/softa...pictorial.html
ill get you size in a minute................
***note*** also easier to at least break it loose when wheel is on ground, then jack up, then remove
