Hey Guys, i have a question on an issue im having with my coil on my bike . It has an older Dyna 2000 ignition module and a dyna mite coil which i do not know if its single fire or dual fire. i cant read the part numbers i only see i a partial date code on the coil 6/97 . Well anyways my coil is down and go the H-D shop and a tech told me i could only use a dynatech coil as a replacement. whats the deal i see others in j&p that are the correct ohms 3.0 and the correct voltage range as well . Whats the difference? any help would be greatly appreciated.
Mark do you think that a drag specialites coil thats dual fire 3.0 ohms 35,000 - 45,000 volts would damage my ignition module? thats the specs for the dyna mite dual replacement coil.
also my bike doesnt have the dyna ignition sensor it looks too be the factory style at least from what i can see. So mine has the igniton module and the coil only if that makes a difference. Thanks for your help
