What plugs and wires are you guys running?
Old 07-25-2012, 02:33 PM
Half-Fast Deuce's Avatar
Half-Fast Deuce
Half-Fast Deuce is offline
Default What plugs and wires are you guys running?
Time for a tune up. Looking for performance plugs and wires. Any suggestions?
Old 07-25-2012, 02:43 PM
tazzzman's Avatar
tazzzman
tazzzman is offline
Screamin Eagle plugs (not High compression) and Thundervolt 10.2 mm wires from Sumax. Also SE coil and ignition module.
Old 07-25-2012, 02:54 PM
jreichart's Avatar
jreichart
jreichart is offline
Stock plugs, uskoolines for wires.
Old 07-25-2012, 03:35 PM
fdb2007's Avatar
fdb2007
fdb2007 is offline
Stock plugs and red Screamin' Eagle plug wires--only because I liked the look of the wires. Have big bore kit and 255 cams, I changed the plugs at 10K and 20K. They looked fine both times.
Old 07-25-2012, 04:04 PM
shitbox's Avatar
shitbox
shitbox is offline
00 Springer softail. Ported and decked heads and screamin eagle cams.
I am running sreamin eagle plugs and black screamin eagle wires. Plugs are 17.00 for the set of two and the wires are around 20.00.
Old 07-25-2012, 04:31 PM
quadrcr87's Avatar
quadrcr87
quadrcr87 is offline
I just ordered the 10mm Screaming Eagle wires and plugs. I went with screaming eagle wires because they were cheaper than other performance wires I looked at.
Old 07-25-2012, 07:02 PM
decencyxdefied's Avatar
decencyxdefied
decencyxdefied is offline
Se 10mm
Old 07-25-2012, 07:23 PM
Mark_H's Avatar
Mark_H
Mark_H is offline
Old 07-25-2012, 08:43 PM
FroggyFatBoy's Avatar
FroggyFatBoy
FroggyFatBoy is offline
Champions and Red SE Wires..
Old 07-25-2012, 08:48 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,571 Likes on 2,889 Posts
Stock wires. All others are for looks.
Quick Reply: What plugs and wires are you guys running?
