What Cams You Running?
Looks like you ride solo, are you looking for peak horse power of low end torque?
Either way you will find a ton of information in the links at the top of the page, or just click on this:
https://www.hdforums.com/forum/softa...-softails.html
If U look at the top of the Softail section..
1. U'll see some threads call "Sticky"" That means there their all the time...
2. Their are only 4 of them....
3. Look for till U find/see the one of the four that is Titiled---
"DYNO" Numbers For SOFTAILS"
I started the thread in the Softail section 4yrs ago just for questions like Urs, when I was looking for a cam and wanted info..
There is over 600 members that have posted what they did, what cams and pipes they used along with dyno's sheets.. well some posted the sheets.
And Yes if U look at the first post in there U'll see my dyno sheets, stock and after cams.
If that's not enough U can go to the Touring section and look up the Sticky Dyno thread for them also. over 3400 results and sheets in that one .
DYNO Numbers for Baggers
If U cant' find them then here's the links...
https://www.hdforums.com/forum/touri...r-baggers.html
I am running Wood 555 cams with a stage 1 (big sucker, PC III, V&H BSS) and I absolutely love them. I have not had it dyno tuned, just running the map that fuelmoto loaded but the place that installed it said everything is running smooth....and they do dyno tuning and so forth so you would think they would try to sell me on it, but they didn't.
I am thinking about doing a dyno run on it just to see where my numbers are so as soon as I do, I will post them. Your numbers would probably be really similar to mine.
