40mph wobble
Old 07-16-2012 | 10:01 PM
KumaRide's Avatar
KumaRide
fall away adjustment on head bearings.
Old 07-16-2012 | 10:59 PM
av8or's Avatar
av8or
Yep, like everybody else has said. Neck bearings.. A little on the tight side is better than a little loose. Just a tiny loose and you've got the dreaded wobble.
Old 07-16-2012 | 11:16 PM
PA1195's Avatar
PA1195
I'll add this at risk of deviating from the service info...but I like to grease the neck bearings with a sticky grease (like HD wheel bearing grease) instead of their low viscosity "special grease". The sticky blue stuff doesn't separate and run oil in hot temps, and "may" add a little dampning to the steering.
The neck bearings still need to be adjusted per the fall away spec, and in my experience the thicker grease stays put in the neck even when exposed to heat.
Old 07-17-2012 | 10:44 AM
bygcland's Avatar
bygcland
I had this problem after the local Harley shop changed my back tire. Brought it back to them and they did an "adjustment" but I still had it. It wasn't until I changed the front tire about a month later the "wobble" went away. Back tire Alignment is crucial it seems.
Rhettm
2014-2023 Touring Models
24
07-31-2021 07:03 AM
skully1200
08-07-2016 05:25 AM
xpilot
09-27-2014 11:43 AM
ShaZAM
07-29-2012 12:49 AM
fl-flhx
12-14-2009 03:15 PM
Quick Reply: 40mph wobble
