Intake manifold removal
What do you all use to get the alen bolts off? I used a alen wrench on the right and alen bit and a box wrench. How can I get a torque wrench in there when I go back together?
BTW it's a 2000 Softail Standard
Thanks
Thanks
Thx for the replys. What i did was cut off half the length of a allen wrench (of the short side). Used the small peice with a 1/4" , 1/4 Drive socket and a small swivel and my inch pound torque and was able to torque the right 2 bolts (carb side) then used the cut allen wrench on the torqued side to fell how tight they were and made the right side as close to that as i could using the cut allen wrench for the left side bolts. Before i used the torque wrench i used the allen wrench on all 4 bolts to evenly tighten the manifold.
