Dying Heritage
Wanted to update. The problem seems to have been simply a bad ground. I did have a little corrosion on my negative battery terminal. After having the battery load tested, it tested good, I cleaned up the terminal, cleaned all the ground cables and the strap at whitch the ground cables mount, added dyellectric grease and she has been good to go so far.
RLH
Electrical/Lighting/Alarm
15
03-23-2019 11:30 AM
