hi guys just wondering if anyone has put a 21'' front wheel on there rocker as i'm looking at doing so just wondering if there was anything i should no about or is it just as simple as getting a softail 21'' wheel and bolting it in ? any help would be great. cheers
There are a few shops that do 21inch wheels specifically for the rocker.. And the answer is no not just any 21 will bolt up take in consideration the size of the hub, distance from hub to rotor and then spacing from hub to forks.. Now, you can make it work but it takes patience and good measuing to make any 21 fit..
I'm building a Girder front end for a guy in another state. He has a Rocker C, and wants to run the original front fender. Does anyone have a take off front fender that I can get some mounting dimensions from? Please let me know.
just got in contact with the blokes at ultima wheels and they tell me i wont get the 21 inch wheel i want without changing my front end over to wideglide front, will this alter the alignment of everything as the front wheel is normally offset on the rocker or wont it matter ?
