Rake on 1993 FXSTC
and i remember the FXSTC had clearly more rake than the Heritage, and assuming that HD probably used the same frame for both Softails, I guess they added the rake for the FXSTC in the triple tree...
but this is only my way of thinking, not sure though...
Received 1,296 Likes
You can tell by looking at the trees/frame neck. Set the bike nearly upright (not necessary, but makes it easier), then back off a bit and simply eyeball the line of the forks compared to an imaginary line through the steering head (neck). If they are parallel, there is no rake to the trees. If not parallel, then there is some rake. Once you've seen a set of raked trees you'll be surprised how easy it is to ID them.
67 LS1
09-26-2006 08:51 PM
