Black fork sliders/cowbells question..
Looks good.. did you put the vinyl on and trim it or did you make a template? I wasnt sure which would be easiest.. Have any issues with air bubbles?
I cut it to the right height, and approximate width, then just let it overlap a little on the back. There are a few small bubbles, but nothing that bad.
Just use clean hands, and work your way around slowly pulling it very tight. Then if it does get a bubble, you can peel it back and reapply as you go.
