Headlight & AuxLight Trim Rings
Folks,Just did a light trim ring install on the '03 Fatboy.Went with the deepstyle rings.Aux lamp rings fit great,as they are clamp style,no probs.The headlight ring has a ton of slop,even after tightening.HD says the part # and part is correct for my bike.Does this ring require the foam strips around the inner part to "seat" the ring or something I'm missing??
Are there any differences in the bucket or nesting ring maybe? Thanks ahead guys
Rip,I did not get an o-ring with the bezel.The headlight itself fastens to the bucket as normal with the nesting ring, no problems there.The bezel is whats giving me grief.It matches the bucket O.D. but seems too much space between bucket,and ring.Maybe this o-ring could be the fix,I'll buzz the dealer. Be back................
Headlight rim
I put the french ring around my passing and headlights. The passing lights fit nice an tight but the headlight had some slop in it and it rattled constantly. Finally had to get some of that insulating foam that use around air conditioners (the real narrow roll) and put some of that around the inside of the trim ring. Fixed it right up.
Part # I have is 69626-99,and it mnts with the tab and screw like the stock ring.Maybe you have an updated piece Ghost' ?? Let me do some more diggin'...................
