Calling all Springers!
Old 06-15-2012 | 03:58 PM
Toy_Jon's Avatar
Toy_Jon
Here's my lil girl........
Attached Thumbnails Calling all Springers!-img_0200.jpg   Calling all Springers!-img_0203.jpg   Calling all Springers!-img_0717.jpg   Calling all Springers!-img_0718.jpg   Calling all Springers!-img_0719.jpg
  #72
Old 06-15-2012 | 08:51 PM
NoRegerts's Avatar
NoRegerts
I'd like to take her for a ride some time...
Kidding, but very nice. Two questions.
Can you run 2-up on that RSD fender, if so how?
How do you like that PM brake. Does it make a big difference. Is it worth the cost?
  #73
Old 06-16-2012 | 10:00 AM
Toy_Jon's Avatar
Toy_Jon
I run 2-up all the time, works great with this fender.
I have a suction cup seat I use, works pretty well.
PM calipers are amazing, Easy install and makes the bike stop so much better then factory.
The stock front caliper is a large single piston that is rediculous.
I now have a 4 piston PM caliper and makes the bike stop in EASILY half the distance.
HIGHLY RECOMMENED PM Calipers.
FYI.... anytime you order anything to work on a Springer double and triple check your parts order. Ive recieved wrong parts a few times due to Springers are rare and they say and they send the wrong parts.
  #74
Old 06-16-2012 | 10:42 AM
NoRegerts's Avatar
NoRegerts
You're running the 4 piston on the front too? I'd really like to see that. The braking sucks.
  #75
Old 06-16-2012 | 10:50 AM
Vic Bronco's Avatar
Vic Bronco
More or less done for the season, will probably be putting on a tag frame with integrated turn signals on it next week, but otherwise I don't plan on changing anything else on it this year.
Attached Thumbnails Calling all Springers!-img_20120616_112730.jpg   Calling all Springers!-img_20120616_112744.jpg   Calling all Springers!-img_20120616_112752.jpg   Calling all Springers!-img_20120616_112736.jpg
  #76
Old 06-16-2012 | 10:52 AM
NoRegerts's Avatar
NoRegerts
Your emblems ended up looking really nice.
  #77
Old 06-16-2012 | 12:42 PM
Milty's Avatar
Milty
Do you have a part number for the pm front and rear brake calipers?
Thanks
  #78
Old 06-16-2012 | 12:51 PM
Toy_Jon's Avatar
Toy_Jon
Heres the front caliper, easy bolt on hardest part was draining old fluid and bleeding new lines etc.......
I don't have my part numbers but I ordered from DR. Vtwin and they knew exactly what i needed etc, like I said make sure they understand its for a springer..... SPRINGER require special parts....
DR vtwin was awesome to work with and sent me the correct calipers immediately I HIGHLY recommend them
alex.busta (09-25-2018)
  #79
Old 06-16-2012 | 02:41 PM
MPopham's Avatar
MPopham
6th Gear
2004 S&S 510 geardrive cam, heads shaved .030, SE comp sprocket, SE 6 speed gearset, diamond cut polished SS spokes, LePera red stiched sseat, polished rotors, 84dyno hp
  #80
Old 06-16-2012 | 05:30 PM
NoRegerts's Avatar
NoRegerts
OMFG I just crapped myself!
How much did that set up run? I'm very interested! No! I'm going to do it!
Quick Reply: Calling all Springers!
