what am i hearing??
Old 06-02-2012, 08:08 AM
jlasoftail's Avatar
jlasoftail
jlasoftail is offline
Default what am i hearing??
I set my timing ahead until i got my ping back. Sounds like a quarter hit on glass, rock hitting fender, hammer on metal.... something loud and distinct. Backed timing off, and at around the same rpm level I'm getting a rapid noise that still kinda sounds like tiny little pebbles hitting the fender. It's a very rapid noise, and only happens at certain rpms/throttle positions. Is this still pre-ignition of some sort or is it just normal engine noise. Like I said, It's not a loud, distinct ping.
Old 06-02-2012, 08:56 AM
heybaylor's Avatar
heybaylor
heybaylor is offline
your still too high on the timing, or you are running a little lean ..
either way fix it ...spark knock is hard on engines
Old 06-02-2012, 11:25 AM
Blk and Chrome's Avatar
Blk and Chrome
Blk and Chrome is offline
sounds like spark knock, rattle and ping, you need to fix it or if you keep riding it it will force you to fix it by breaking
Old 06-02-2012, 12:27 PM
jlasoftail's Avatar
jlasoftail
GRRRRRR!!! I'm about to loose it. I thought I finally had this problem fixed. I'm not even sure what to try anymore. I've set my timing back 'till the bike ran like ****, i've added octane boost, I did a cam swap and dropped my ccp by 20psi, I tried seafoam to clean out the carbon, plus ran cleaner with the fuel, i've run a rich afr, my plugs look perfect, what else do i do?
On the plus side, the bike pulls strong, great power, no dead spots, so maybe I just ride it until the piston breaks.
Old 06-02-2012, 11:39 PM
beasleyiv's Avatar
beasleyiv
beasleyiv is offline
Probably a rattle. I have the same thing at about 2500 and 2780 RPM. It isn't knock, it happens under a no-load condition. Besides, the ECM will adjust the spark tables if it sees knock enough in one area of the map. I've seen it pull several degrees on its own where I had a real lean condition in a few cells. I think I've checked every nut a bolt on the bike and can't come up with anything. I swear it is an exhaust heat shield rattle/buzz. I may have to loosen them all up, adjust and tighten again. I just stay off those two particular RPMs for now.
Old 06-03-2012, 06:26 AM
Blk and Chrome
Have you had anyone else ride it to hear the noise? Just a thought is to have someone ride it and see if they hear it. Sometimes we pick up on somethings that are there and key in on them so much they sound a lot worse than they are.....one more thought have you removed the tuner and just run it on the stock ECM and see how it goes? does the noise go away?
Old 06-03-2012, 09:42 AM
jlasoftail's Avatar
jlasoftail
yeah, the guy that helped me put the cams in took it out for a ride. He said he tried and couldn't make it ping. Not that I don't trust him, but he's, well, lets say getting up in years and doesn't hear as well as he used to. But, that being said, I'm thinking that's a possibility. I'm scared I'm just focusing in on it to much, and god knows what I'm hearing. I'll not wast my time at the dealer because all they ever say is that they can't hear anything, or "every harley does that". They're probably right, lol. And yeah, no tuner, tuner, makes no difference.
Old 06-03-2012, 09:45 AM
jlasoftail's Avatar
jlasoftail
You know what? I'm going out for a ride today, and since timing doesn't seem to change anything at all, I'm putting it back up to normal instead of retarding it everywhere, I'm gonna put on my tunes, and I'm gonna forget about it. It's not putting metal flakes on the plugs so I'm pretty sure it's not blowing holes in my pistons. If the bike blows up, I'll rebuild it. Maybe even go a little bigger
Old 06-03-2012, 10:57 AM
NDBadlands4-2's Avatar
NDBadlands4-2
NDBadlands4-2 is offline
I had a similar issue in a car I owned years ago. Dove me nuts trying to figure out what was wrong with the motor. Turned out to be a loose AC bracket. When it rattled it sounded just like a spark knock.
Old 06-03-2012, 11:55 AM
oct1949's Avatar
oct1949
oct1949 is offline
At times I get what I call a Bongo drum sound from the motor, just a steady real fast beat, used to hear it when I first got the bike.
Like above said, sometimes when we listen for a noise we hear it a lot more.
I quite listening for it and now I don't hear it any more..
Thinking,,,When we get focused in on something, we can make it worse than it really is sometimes.
Add.... I just remembered that some tourning bikes back in 07 had what they called rocks rattleing in a can noise at lower rpm and under load.. but it was usually a loose compensator.. lot of members put in the SE comp to help also..
But Ur new 12 bike comes with the SE comp.. but it might still be loose...
Quick Reply: what am i hearing??
