FXSTBI wont start after coil relocation and other mods
Got a 2006 night train.
Mods that might be affecting the bike from starting.
Installed gripace system - problem free, all functions work like they should. Instsalled like the instructions state.
relocated coil to where horn was. All I did was extend the 4 wires going to the rear of the coil to reach the new location and mount.
What about ground fore the coil? I removed the seat post that the coil was originally installed on. I figured the post grounded the coil so I hooked a wire to each bolt and then then a wire to a ground on the frame. Temporarily until I can get it started, then neating it all up.
The gripace system instructions ask to hard wire the run/stop wires together, i opted to install a physical hidden toggle switch instead of the ignition and fuel pump turning on every time I turn the **** on the tank. I wanted them seperate.
Now that I have put that tank back on and hooked up the wires into the conenctors and what not, it will turn over and there is fuel, air and spark, but will not start and run.
Im really frustrated and concerned at this point.
Is there something i needed to do with the gas tank when hooking it back up? Purge the line or anything? All i did was hook the quick disconnect fuel line on the coil side back on and put fuel in it.
Help on this matter would be awesome as Im at a stand still until it fires and stays running.
Sounds like it could be any number of things, and nnot to get away from your particular issue, but you shouldnt need those ground wires you put to the bolts on the coil you relocated. Just saying. I'd check the grip ace wiring first and fore most. And throw up some pics, did you cut yoru own grips or use supplied ones?
appreciate the responses. Going to see if the battery is the issue. Read that the battery needs to be fully charged to supply sufficient power to the ECM and the rest of the bike including enough juice for the starter.
Im hopin its a simple fix, cuz ive spent too much time and $s messing with this. These mods have made me not want to work on my bike again.
