Installed full LED turn signals on my 12 Heritage about 1,000 miles ago. This included LED tail light, LED rear turn signals, and LED front turn signals. Still have the stock Headlamp and aux lamps... Suddenly the right turn signal stopped working this AM and then the left. The left turn signal has 1 LED still lit up but it just stays lit. Rear lights and brake work correctly. Any ideas on what may be wrong??? Thanks for any help.
Thanks for the reply, sorry my bad, didn't give enough info... The LED lights are all HD and are supposed to be "plug and play".... yeah right... Anyhow, none of the lights came with a load equalizer, was told it wasn't necessary if these were HD version.
Sounds like bad LEDs. I've got custim dynamics leds all the way around & a similar thing happened, couple of bad leds in my rt signal. Leds are all or nothing, uf a couple went out then the entire led module has to be replaced. Hope its still under warranty, best if luck
