Advice on starter
Old 05-07-2012 | 04:30 AM
deadeye's Avatar
deadeye
Default Advice on starter
I think my starter is giving out. Bike runs great but sometimes have to punch the starter a couple times before it actually turns the engine over. I replaced the battery last year and well, I've had bad starters before on other bikes, so I know the symptoms.
Anyway, I've heard this is a common problem on 07 HD? Oil leaking into the starter? I think I read that somewhere..
Should I go with a stock replacement or aftermarket? I'm not just looking at the cheapest option. If some of these starters have a design flaw causing them to die early, I don't need another stocker.
Thanks in advance
Old 05-07-2012 | 09:45 AM
Figstr's Avatar
Figstr
I had the same problem on my 07. It was the starter clutch.
Old 05-07-2012 | 05:42 PM
deadeye's Avatar
deadeye
figstr - So you didn't change the whole starter? How much did that cost?
Old 05-08-2012 | 12:10 AM
oct1949's Avatar
oct1949
Sorry I have not heard this is a common problem on the 07's
IMHO It'd save U money to take her in and let a good wrench see what's wrong instead of throwing money at her not knowing what it is.
Could be as simple as Ur switch. or wiring issue.
Old 05-08-2012 | 03:26 AM
kaynine840's Avatar
kaynine840
no need to change the whole starter. there's only like 3 parts that can go wrong with it. the armature, solenoid, and most likely the starter clutch. if you decide to change the clutch, buy an aftermarket one with a lifetime warranty cause the stock ones are junk. toyota uses them in some of their cars, except they sell them for alot cheaper than harley. all ***** sells a good starter clutch and so does zen. and if you're going to change it out, go ahead and get a solenoid kit as well. just cause they're so cheap.
Old 05-08-2012 | 09:04 AM
Figstr's Avatar
Figstr
I got the starter clutch at Harley and don't really remember how much it was. The install wasn't cheap as I had my Indy do it. If I remember correctly the total was about $150 - $200 with labor. The starter clutch wasn't that expensive.
NickSchoff
EVO
04-05-2013 09:26 AM
cabowabodude
09-12-2011 11:52 PM
jonbyrd73
Exhaust System Topics
06-17-2011 12:56 PM
mostSilly
EVO
06-11-2010 10:49 AM
msdenice
11-05-2007 06:24 PM
Quick Reply: Advice on starter
