Wrapping Big Radius Pipes
Old 01-03-2007, 04:19 PM
Lunder99's Avatar
Lunder99
Lunder99 is offline
Default Wrapping Big Radius Pipes
I am considering wrapping my big radius pipes with black header wrap to match the rest of my night train. Has anyone else tried this on their big radius pipes and with what results?
Thanks,
Chris
Old 01-03-2007, 08:39 PM
ChopperHammer666's Avatar
ChopperHammer666
ChopperHammer666 is offline
Default RE: Wrapping Big Radius Pipes
Have you used the pipes yet? If not you can get themceramic coated flat black. It won't work on used pipes. If you still want to wrap the pipe, I've heard wetting the wrap makes it easier.(I haven'ttried)
Old 01-04-2007, 01:56 AM
davzdorado's Avatar
davzdorado
davzdorado is offline
My experience with wrap wasn't good.
I loved the look for about a month but then, it doesn't stay black, it will start turning white, unless you spray it again with some ceramic paint. I felt it put off more heat to my leg than with the heat sheild.
Hope this helps..
Old 01-04-2007, 11:20 AM
twowheelsforever's Avatar
twowheelsforever
twowheelsforever is offline
just curious, why can't you get used pipes ceramic coated? I have a set that I've had on my bike for about six months that I was looking to get coated this winter...
Old 01-04-2007, 11:53 AM
In Memoriam Citoriplus's Avatar
In Memoriam Citoriplus is offline
May our Moderator Rest in Peace
According to Jet-Hot, you can get used pipes coated. I asked them about my getting my 07's done and they said its not a problem. Iguess as long as the pipescan stand the cleaning/blasting process your fine.
Old 01-04-2007, 12:04 PM
flt04lee's Avatar
flt04lee
flt04lee is offline
i have my own powder coating shop and i do ceramic coatings too.yes you can coat used pipes.you are better off using old pipes because the right way to ceramic coat is to strip the part to bare metal so you should have the chrome stripped off...so why mess up a new set of chrome pipes....
Old 01-04-2007, 02:58 PM
davzdorado's Avatar
davzdorado
I have a question about ceramic coating. I had my pipes done last week and when I went to install them they chip really really easy. I can almost chip the paint off with my finger nail ! How durable is should the paint be ??
Thank you....
Dave...
ORIGINAL: flt04lee
Old 01-04-2007, 05:26 PM
twowheelsforever
If they were actually ceramic coated, there's no way it should just chip off. Either they didn't prep correctly, or they didn't actually ceramic coat them...
Old 01-04-2007, 08:40 PM
flt04lee's Avatar
flt04lee
flt04lee is offline
whats it look like under the ceramic coating...theres no way it should chip...metal not prepped right or undercured...
Old 02-27-2007, 01:05 AM
Bradley's Avatar
Bradley
Bradley is offline
how much does it cost to have the pipes coated? My POS samson street sweepers are pitting already, dispite constant polishing.
thx
Quick Reply: Wrapping Big Radius Pipes
