Wide Glide bars on FLSTCI
01-02-2007, 10:01 PM
So I had a friend give me the stock bars off his Wide Glide. I'm thinking about putting them on my 03 FLSTCI. Do you think I'll still need longer cables?
01-03-2007, 12:38 PM
RE: Wide Glide bars on FLSTCI
I just put the same bars on my Deluxe. The best I could do is "dummy up" the cables to see if they fit once the bars are on. I had to work closely with my HD parts guy, and depend on his knowledge of how long cables for different bikes were to find the right ones. For some reason HD doesn't have the length of the cables in the part description. I ended up using the stock throttle cables, a brake cable off a Wide Glide, and a clutch cable off something else, the parts guy found one that was about one inch longer but I cant remember what bike it was for
01-03-2007, 01:55 PM
I've had wideglide bars on my 04 heritage. They are a direct bolt-on. The most you'll have to do is slightly bend the brake line.
01-03-2007, 08:44 PM
Are these the same bars?
[IMG]local://upfiles/20838/0B95EB83DD224F8195331CAED2A54659.jpg[/IMG]
01-04-2007, 02:24 PM
Looks like the same. They ones I have are the stock bars off a 06 FXDWG.
If flstcbob's fit, I've got to believe it will work for me also.
01-04-2007, 03:44 PM
Did he give you the risers? I have a second pair of 1.25" risers off a Wide Glide if you want them.
01-04-2007, 09:32 PM
I had planned on using the clamp that I already have, I think they'll fit.
Maybe you have the 1 1/4 bars?
01-04-2007, 11:03 PM
I do
01-05-2007, 02:46 PM
Thanks for the help, and if I decide to go with the risers I'll give you a shout.
vcm321
03-09-2018 04:55 PM
SPCJ
09-04-2015 01:24 PM
hoghead58
06-21-2014 06:10 PM
terrapin88
04-21-2011 11:44 AM
teambft
04-20-2008 06:17 AM
