Will a 250mm Avon fit on a Rocker with no Mods?
Sorry if this question has already been asked and answered but I searched for a while on here last night and couldn't find one.
Will a 250mm Avon Cobra 250/40-18, mounted on a 8.5in wide rim, fit on a Rocker that has the stock setup with no mods to the swing arm? Stock setup for a Rocker is 66 tooth, 1in wide pulley and 11.5in rotors. I'm installing a Heartland kit (not the 280 kit) and want to fit as much rubber under it as possible without rubbing or having to pull the primary to change out the belt for a thinner unit.
Plenty of info on the 260 Metz fitting the Rocker but I'm hearing the Avon 250 is actually wider...?
Doing some mods at the house so want to be sure before I order new wheels and vendor couldn't say for sure. Here's a teaser pic of the Heartland mocked up in my garage..
Thanks RD. I'm not wanting the change out the belt if at all possible. Don't like the thinner unit (seems too small to handle my style of riding and a passenger?). Plus with everything I'm doing I'm not wanting to pull the primary to switch the belt...too much work and pain in the **** lol. Love the look of your bike though...
Theronqbunnell
Welcome Area Only
17
09-11-2009 10:00 AM
