Which cam is right??
Need help. Own an '02 Heritage Classic, stock 88", stock exhaust. 40K miles. Looking to keep the girl for at least two more years. Lots of Hwy solo driving coming up. Need to replace tensioners. Looking at going to hydraulic lifters. now if you were going to change cams(looking for HWY passing pwr), need advice. Anything else I should replace...tappets?
EFI demands a tuner, Power Commander III or SE and a SE intake.
http://www.bigboyzheadporting.com/tccams.htm lets you compare cam specs.
IMO the SE 203 is just to close to stock. The Andrews 21 and 26 are an improvement, but the SE 204 is best for an otherwise stock 88.
I have a 2:1 exhaust with a SE intake, K&N filter, SE 204 cams and PC III dyno tuned to 80+ tq just off idle thru 5000 and 82 hp at 5250. Very happy with it.
Love the 26h's in our 07, 96'er, also thing the 21 or 26's, the 21 have a little more lift but their intakes closes a little earlier.
Agree the 204 are good,, but as far as saying their the best,,???? on that.
For solo U can also look into some And 37's
Look through here to see the diff grinds on most cams.
http://www.bigboyzcycles.com/tccams.htm
And its been posted in here lately,, make sure U install the roller chain on both front and rear when and if U go to the new HYD tensioners system.
READ through this thread.
https://www.hdforums.com/forum/softa...ot-at-20k.html
