For those with 18" Gangster apes
The poly riser bushings help, but the best option is to get the 1.5" bars with the Carlini risers that have the built in set screws that hold everything in place. If you have excessive flex I would say maybe torque down the lower riser bolts a bit more under the triple tree. The taller the bars are, the more leverage therefore the more change of movement as well.
agree with everything mentioned above. It is the way to go. Poly riser bushings and the Carlini Risers.... Dont have much flex on my sled with this setup.
