You can't put a stock brake caliper back on.It will look awful... HHI baby... And in all seriousness, you may really not be able to reuse the Springer front caliper on an aftermarket rotor...
And the hits just keep on coming!
I'm hopeful that I can use by stock caliper, at least for a little while. Sinister has a HS in their gallery with a 21" front and matching rotor. It looks to be used with the stock caliper, though there is a chrome cover on it.
A 4 piston HHI caliper is on the list, just not at the top of the list.
Thanks for the heads up, and that looks damn nice on your HS. Bleeding chrome!
Before swapping to the aftermarket rotor you need to check the coverage area of the stock caliper on the stock rotor.... If you look at the spokes on my rotor... The stock caliper brake pad hangs lower and would have be into the spokes.
HHI are usually in stock. I've never waited for one
Do you recall the kind of pads that come with it? I was thinking about swapping to Lyndall Z+ pads since they are more "gentle" to the polished rotors.
Amazon has them too. Not as bad as I thought price-wise...I might just say screw it and make the purchase...
