Just ordered 39 Inch Cholos
Old 04-22-2012 | 09:45 PM
Samson_info's Avatar
Samson_info
Former Sponsor
On the 1995 bikes the frame is already drilled and tapped with mounting holes on the left side. You may have the plastic plugs still in the frame. They can be removed by prying them out.
Thank you,
JR
Old 04-22-2012 | 10:25 PM
ghostrider69's Avatar
ghostrider69
Originally Posted by Toptrigger630
FES,
I'm getting worried about the install. I just saw another thread where a guy was installing tails on his 95 Nostalgia. The left side of the frame where the bracket mounts on the older models apparently does not have the plastic plugs and his was steel....Mine is the same way. Is that your bike, and if so did you have to drill and tap the frame to mount the left muffler bracket?????????? The title of the thread is "did I just get screwed out of $900 for samson pipes" if you want to reference his thread. Some of the responses are pretty colorful regarding the OP bashing Samson, If I have to get the frame drilled and tapped then its Ok with me I'm just trying to prepare for the install when they get here. Thanks in advance.
Yes, he had to drill and tap the frame. If yours is the same as the one in the thread that you mentioned then just do as I advised the other to do. Go ahead and get the right side bolted up where you want it. Then loosely bolt up the left side with the bracket bolted onto the tail pipe. Use a block of wood to support the left side and make sure it is sticking past the fender just as the right side and that it is level with the right side. Then with the bracket against the frame use the holes in the bracket to mark the frame where you need to drill the mounting holes. Remove the left tail pipe and drill and tap the holes. You will need a 5/16 drill bit and a 3/8"x16 tap. When you get the tap to start cutting threads just screw it in about 1/4 to 1/2 a turn then back it all the way out to clean out the cuttings so you will not jam up the cutters and break the tap. Use thread cutting oil (tapping oil) in this process.
Old 04-26-2012 | 03:58 PM
Toptrigger630's Avatar
Toptrigger630
3rd Gear
To JR from Samson,
Not to sound like a smart a&*, but my bike nor does the one referenced from the other thread have the plastic plugs on the left lower frame(his is a 1995 FLSTN)...the newer bikes do. Samson should do some research on this and include it in the instruction manual. I've looked at the bikes with the plugs, most are 2000 and newer. Mine has the little raised nipples on the frame but there are no pre drilled holes or plugs, its solid steel, the other guy caught hell for it too, but it turns out he was right... I'll be glad to send you a picture but if you look at the thread I referenced the guy already has pictures up... Mine looks just like his. it's a 1996 FLSTN. The part number ordered for my bike is
S-438 for 96-07 Softail.
Thanks
Old 04-26-2012 | 04:07 PM
fRESH88's Avatar
fRESH88
yeah that other guys was right
Old 04-26-2012 | 05:19 PM
Samson_info
Former Sponsor
I apologize for any inconvenience this has caused anyone.
Thanks,
JR
Old 04-26-2012 | 05:27 PM
AZ_LJ's Avatar
AZ_LJ
Will this set up work on a 93 springer if not does anyone make something similar to these that will work??? I've looked every where but it seems nothing is available before 96. Can anyone help?
Old 04-26-2012 | 09:52 PM
Raddazzz's Avatar
Raddazzz
My bikes a 1997 heritage, it had the plastic plugs on left side. I put 33 baffled fishtails on in about two hours,,,the pipes are awesome!
Old 04-27-2012 | 10:54 AM
Benway's Avatar
Benway
Little 'tip' here: Grind the point off the tap and you're get more threads without having to drill quite so deep.
Old 04-27-2012 | 11:38 AM
2006FLST's Avatar
2006FLST
Yeah there was a cut off around (I think 95 or 96 for those plugs). My 97 has the threaded holes already with the plugs.
Old 04-27-2012 | 01:32 PM
ghostrider69
I think the holes are drilled thru the frame. If not you can just buy a tap that does not have the point on the end.
Quick Reply: Just ordered 39 Inch Cholos
