Can't seem to catch a break, metled battery terminals.
Old 04-10-2012, 01:31 PM
hoethree's Avatar
hoethree
hoethree is offline
Holy Chit man! That battery is smoked! Gonna have to trade that bike in on a new one now!
Old 08-09-2012, 11:42 AM
1990FLTim's Avatar
1990FLTim
1990FLTim is offline
Stage II
Default My terminals to, but....
When I go to put the new battery in. It melts the battery terminals the second I put the cable to it. I pulled the ground cable and cleaned and put back in but same thing -- would love some help!!
Old 08-09-2012, 01:08 PM
Liberator's Avatar
Liberator
Liberator is offline
WAH!?!? Holy hell, your hot must absolutely be going to ground somewhere!
Old 08-09-2012, 01:40 PM
Scaredofrain's Avatar
Scaredofrain
Scaredofrain is offline
Your positive WILL have a fault to ground. No two ways about it.
Old 08-09-2012, 06:51 PM
FroggyFatBoy's Avatar
FroggyFatBoy
FroggyFatBoy is offline
definitely a short to ground on the main battery cable. it has to be between the batt terminal and the main fuse. if it was after the fuse it would pop the fuse. could also be a fried starter. the battery cable goes down directly to the starter on the main lug. there is no fuse in that circuit. disconnect the cable from the starter, protect/cover the end of the cable and reconnect to battery. if all is well you have a bad starter.
with the abuse those cables have taken i would highly recommend replacing both positive and negative cables if you haven't already.
Old 08-10-2012, 12:32 PM
Scaredofrain
Good thinking Batman!
Old 08-10-2012, 06:30 PM
FroggyFatBoy
don't forget to disconnect the batt cable at the starter...
Old 08-12-2012, 12:20 AM
In Memoriam Citoriplus's Avatar
In Memoriam Citoriplus is offline
May our Moderator Rest in Peace
I would hand trace the positive battery cable before I did anything else.
It HAS to be cut, nicked, or worn through at some point where it can touch the frame, oil tank, or some other grounded part of the bike.
ANY other kind of electrical short is likely to be after the main fuse and that would blow the fuse long before the terminals got warm, let alone melt.
Even a short in the starter solenoid would probably just spin the starter over as soon as the cable touched the battery.
Old 08-12-2012, 12:41 AM
Beagletim's Avatar
Beagletim
Beagletim is offline
Wow...never seen one that bad! Sounds like you have lots of good recommendations already posted.
Old 08-12-2012, 12:56 AM
JWitz's Avatar
JWitz
JWitz is offline
To melt like that takes some serious current.....it is not a loose connection...it is definitely something shorting out somewhere.....
Quick Reply: Can't seem to catch a break, metled battery terminals.
