Clutch doesn't seem to be fully engaging
I have read many of the posts in the forum regarding this subject, but just want to ask about it again.
My 06' Softail Custom, symptoms:
1. when starting the bike while in 1st gear, it trys to move a bit
2. so, starts in neutral fine, but when shifting it goes hard into 1st, with a rather hard/loud clunk.
3. while in 1st gear, with clutch handle depressed, the bike doesn't roll as freely as when in neutral. It again seems that the clutch doesn't fully engage. This symptom is both with the engine running or with the engine off.
I have performed the clutch adjustment, per manual.
Any ideas?
Any ideas?
Any ideas?
Any ideas?
Mike
The title of this thread is a little misleading. After reading your question, what you're really asking is about clutch disengagement, not engagement.
As long as your clutch doesn't slip under load you should be fully engaged. Now, when disengaged the drag you are feeling is typical of wet clutches. The cause is the binding effect of the oil between the clutch plates and it is perfectly normal.
As for starting the bike in gear with the clutch disengaged, that puts extra load on the starter and is not something I would do except in an emergency situation. Starting it in nuetral is the more desireable method.
And pushing the bike in gear with the clutch disengaged, well that puts more load on yourself. Won't hurt anything on the bike, but why put yourself through the extra effort. Put it in nuetral.
Mine does all that when it's cold, but not after it's warmed up to normal operating temperature. When I start it cold, I always start it in neutral. Even after it warms up for 5-8 minutes, no matter how long I hold the clutch in it still clunks going into gear.
After it's fully warmed up though, I don't have any of the issues anymore. I can pull in the clutch to roll it while it's in gear and it's just like rolling it in neutral. Same with starting it in gear after it's up to running temperature (although I still usually put in neutral before starting it). Also, after it's fully warmed up, if I hold the clutch in for a few seconds before putting it in gear it doesn't clunk at all; shifts into gear silently.
...and yeah, clutch pulled in is disengaged, not engaged.
