Clutch adjustment
Old 04-04-2012, 10:37 AM
RaymondTM's Avatar
RaymondTM
RaymondTM is offline
6th Gear
Default Clutch adjustment
Is it necessary to replace the clutch cover gasket when re-installing the clutch cover?
How 'tight' is 172-120 in.-lb., for the clutch adjusting screw locknut?
Thanks!
Old 04-04-2012, 10:41 AM
Cansoldier's Avatar
Cansoldier
Cansoldier is offline
Im wondering the same thing? Anyone?
This link might help you.. good video!!
https://www.hdforums.com/forum/dyna-...st-gear-2.html
Old 04-04-2012, 10:45 AM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,571 Likes on 2,889 Posts
Ive been using the same derby gasket for 5 years. Biggest tip is to make sure you are using a torx t-27 and not a 25. A little anti seize and not locktite is also a good idea. Dont know the torque.
Old 04-04-2012, 10:55 AM
Crash75's Avatar
Crash75
Crash75 is offline
Ditto to all the above.....I had to buy a t-27 just for that since my torx set skipped that size. I also used anti-seize...not locktite.
Old 04-04-2012, 11:15 AM
RaymondTM's Avatar
RaymondTM
6th Gear
Thanks, everyone.
Is it necessary to use a torque wrench on the adjusting screw nut, do you think? The spec is 172 - 120 in.-lbs.
Old 04-04-2012, 11:38 AM
smdugan's Avatar
smdugan
smdugan is offline
6th Gear
172 in-lb is about 14 ft lbs which if uve ever torqued alot you know is not a whole lot
If you don't have a torque wrench id try to borrow one if you can't borrow one I'd say snug it up w a 1/4 drive ratchet with ur hand on the head of the wratchet and not down on the handle should b pretty close
Old 04-04-2012, 11:48 AM
RaymondTM's Avatar
RaymondTM
6th Gear
Thanks, smdugan.
Old 04-04-2012, 12:01 PM
JohnFlorida's Avatar
JohnFlorida
JohnFlorida is offline
You can reuse the gasket as long as it wont leak. Throw away the torx screws and replace with button head allens
Old 04-04-2012, 12:10 PM
jayc67's Avatar
jayc67
jayc67 is offline
I've reused the gasket several times, and I never torque those screws, just get them snug with antisieze on them. There is no pressure inside the primary case so you're really only sealing the derby cover against splashing around and the pooling you get when the bike is on the sidestand.
I do like the newer full size paper gasket instead of the older o-ring. Not sure when they switched.
Old 04-04-2012, 12:23 PM
RaymondTM's Avatar
RaymondTM
6th Gear
Thanks, good idea about changing the screws out.
So, what the torque on the adjusting screw nut? Very important to use a torque wrench, or no?
Quick Reply: Clutch adjustment
