Clutch issue?
Clutch issue?
I've been riding for 30 years and just recently have taken an interest in doing as much of my own work on my bike as possible. So here we go
99 springer softail is my baby, and we were out riding sat nite. 1st gear smooth
2nd gear just fine , 3rd gear... Perfect, 4th gear whoa where'd it go?
Got it home(trailer), changed tranny fluid (75w), no metal on drain plug
Drained primary, cleaned everything looks good.
When it sits cold, if I click in gear, it seems normal, can't pull or push bike.
Start it up, click in 1st, and let the clutch out.... Nothing, not a thing in any gear.
Any ideas are appreciated.
Did you try to push or pull the bike while it was running and in gear with the clutch lever out as you did when it was not running? You said that when it sits cold, I assume you mean not running, your could not push or pull the bike. Did you try to push or pull it while in gear with the clutch lever pulled in when it was not running?
Pull the derby cover,Loosen jamb nut while holding the allen. Back allen out, then thread it in until you have very little clutch pull(a little is good) should feel it seat, tighten jamb nut. An offset wrench makes this much easier. You can fine tune on the clutch cable as there is an adjuster about the middle if the cable. Buy a manual man, worth its weight in gold.
I adjust my cable to where I get enough play for a loose dime at the clutch lever but not enuff for a nickle. If the clutch needs adjusted behind the derby cover, piece of cake. Watch the video is the easiest way to explain.
http://www.youtube.com/watch?v=Qw6da...eature=related
NCBANDIT
03-11-2019 04:52 PM
BuzzCap7
17
05-06-2017 09:21 AM
travalab
06-28-2013 01:01 PM
