Blackline - Convert seat to solo?
Hey there...forum noob here with a question for Blackline owners that converted their stock seat to a solo.
I've already cut the back section off. My question is did you somehow reuse the stock mounting bracket and, if so, how did you attach it to the seat?
Any pics you can post up would be greatly appreciated.
TIA!
TIA!
Is the bracket screwed to the back part of the seat or is it riveted? Either way remove it and then put your seat on the bike where it goes. Then slide the recently removed rear bracket under the seat so it aligns with the mounting hole on the fender and mark the poisition. If it reaches far enough under the seat mark the holes and rivet or screw it on the seat base and your done.
If it doesn't line up you may have to make a custom rear bracket out of you favorite flat stock and attach it the same way as stated. Thats how I would do it. Good luck with your project.
