Fix small Slip on leak???
Just finished my first upgrade that included removing the stock exhaust and adding a set of Rush 1.75 Slip Ons. My basic question is if there are small exhaust leaks that are not causing any issues like Decel pops should I still remove and reinstall using some Penetrex Copper or just enjoy. I only found the leaks by using a high power light to inspect the join while looking down the end of the baffle. I used new clamps to secure at 65 ft lbs of pressure as reccomended. Thanks in advance.
