bright headlamp??
Old 03-21-2012, 07:57 AM
softailJoe's Avatar
softailJoe
softailJoe is offline
Default bright headlamp??
Was wondering what people on the forum are using for bright headlight an there softails , not happy with the light mine throws out ?
I bought a aftermarket stretched jobby and being a 99 softail standard, ridged mount motor thought that might be an issue as well with the vibration the bulb and longevity?
Anybody have some ideas of what has worked for them or there buds would help ?
Cheers ,Joe
Old 03-21-2012, 08:08 AM
Tampa Fatboy's Avatar
Tampa Fatboy
Tampa Fatboy is offline
Received 10,435 Likes on 4,752 Posts
Replaced the stock 9003 with one of the super bright replacement bulbs from the local automotive shop.
Old 03-21-2012, 08:24 AM
08rock's Avatar
08rock
08rock is offline
The HD LED is pretty awsome. Plug and Play and very bright
Old 03-21-2012, 10:08 AM
Joker_Hal's Avatar
Joker_Hal
Joker_Hal is offline
You have two options. HD and kuryakyn both make a good LED head light. A Side by Side comparison shows the HD light is brighter, both the low and high beams. However it will also cost somewhat more. Both are much better then the stock light. It's up to you if the extra brightness of the HD is worth the extra $$.
Old 03-21-2012, 10:13 AM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
The first and easiest thing to do is to pull the diffuser out of the headlight. The diffuser is the piece that covers the end of the bulb. 55W bulbs are what we usually run in our older bikes. It is held on with a screw and can be either removed completely or you can twist and break it off.
Old 03-21-2012, 12:59 PM
dub976's Avatar
dub976
dub976 is offline
I got this from autozone to convert my sealed beam on my fatboy, dot approved came with a bulb. brighter then my buddies 09 dyna stock light.
amazon link
Old 03-21-2012, 01:30 PM
rmfischer's Avatar
rmfischer
rmfischer is offline
I went with the LED lights from Harley and all I can say is wow. They are incredible. If you search youtube you will see videos of the comparison. After watching those and reading all sorts of reviews i decided they were the way to go and so far i have no regret.
Old 03-21-2012, 02:04 PM
SprungDave's Avatar
SprungDave
SprungDave is offline
LED lights are bright, but very expensive. I would consider a brighter replacement bulb and wait for a year or so. the LED's will be cheap by then. $800 may seem reasonable to some - and you can't put a price on safety - but folks who buy the LED now are the "early adopters" and will be paying a premium for the bulbs at this stage in the game. Perhaps consider a HID kit. Those are now $40. They used to be $500 too just a couple of years ago.
Old 03-21-2012, 02:17 PM
rmfischer's Avatar
rmfischer
The 7" led is I belive $495 and the 5" $395 not $800. If you go to the right places you can get those for 15-20% off. Thats still not cheap but considering the safety factor of being able to see I feel its worth it. You are right they may be cheaper a year or two from now just like everything else its a matter of what is it worth to you. There are pros and cons to any option you choose.
Old 03-21-2012, 03:43 PM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
I did the sealed beam swap on my ride long ago as well. I think 03 and up use standard bulbs but can't remember.
Quick Reply: bright headlamp??
