Neck bearing replacement...
03-19-2012, 11:13 AM
Whats the trick to getting the lower neck bearing off the tripple trees?
03-19-2012, 12:11 PM
The service manual says you can use a chisel to start it loose and then pry it off with a screw driver.
The best was is to use a bearing splitter IMO.
03-19-2012, 12:47 PM
Heat it up with a torch and it should drop right off... You'll have to get a new bearing. I turned it upside down and held a torch on there for a while all the way around and it eventually just fell off. If you pry too much with a screwdriver you'll scratch the crap outta the trees
03-19-2012, 02:07 PM
Time to bust out the torches I guess!
03-19-2012, 02:55 PM
hell ya dude. Took me about 5 minutes of goin around it to get it hot enough, then it dropped right off
03-19-2012, 03:00 PM
I dont know if it even took me that long! Tyanks for the tip. It dropped off right away!
cvaria
04-29-2016 08:11 AM
trozenhorse
03-13-2011 02:51 PM
rounder
12-30-2009 10:33 AM
fiveola
Shovelhead
09-22-2008 07:35 PM
MikesWideGlide98
07-25-2007 04:57 PM
1996 ,
bearing ,
bearings ,
dadivdson ,
fxst ,
harley ,
low ,
neck ,
repair ,
replacement ,
replacing ,
rider ,
size ,
sportster ,
touring
