Wild 1 Wires, Does this sound right?
I guess my question is, which brake line do I need out of the ones listed.
E-Z Align Single Disc Front Brake for 2006 FLSTN/I Heritage Softail Special (Deluxe)
or
Swivel Fit Front Brake for 2006 FLSTN/I Heritage Softail Special (Deluxe)
or
Designer Upper Brake Assembly for 2006 FLSTN/I Heritage Softail Special (Deluxe
or
or
These should be the stock lengths for the cables
Clutch 63" (actual is 62.5")
Throttle & Idle 31"
Brake 45"
You'll probably need a 15" wiring harness extension.
You'll also want the HD poly bushings part #56165-03
My damn pain meds and the night air from my ride last night must have made me pass out early with the laptop on my lap. lol I was looking on here last night and there is a boat load of information here on the site for this setup. You may also want to pick up the free parts catalog from the stealership if you don't have one.
Throttle & Idle 31"
Brake 45"
or
or
or
or
With that said, They told me I'd need +12 on all my cables and that ended up being a little too much for my 16" Flying Apes (measure around 18"), could've gotten away with +10 all the way around.
From what I've read on here for your bike and bars +8 should be fine.
After looking through the magnum website looking for my cables I had the same problem as you, asked the same question and unfortunatly didn't get an answer. I finally just ended up calling Dr. V-Twin and told them what bike I had and what bars I was putting on. They ordered everything for me and it all worked perfectly.
![Frown](https://www.hdforums.com/forum/images/smilies/frown.gif)
