SERT, PCIII, (Or Neither)
RE: SERT, PCIII, (Or Neither)
If you're going to start adding performance mods to your bike, you're going to need one programmer or another. All have their own advantages and disadvantages.
FWIW, I chose Dynojet's Power Commander III USB. Any dealer with a Dynojet or other brand of dynamometer can "fine tune" your bike with it or you can just download a "canned" map for your setup from the Power Commander web site or elsewhere. These generic maps will get you close enough so that your bike will run fine and they're convenient if you're not worried about getting the last ounce of horsepower from your mods.
ORIGINAL: Heritage07
Heard the same thing supposedly the sert reads and adjustthe ecm condition over a wider rpm range then just a flash download.I guess it is like micro tuning so the bike never has a flat spot.All I know is it works!
the SERT is used to download a new MAP to the ECM, just like the dealer would do.
the difference is that with a SERT you can adjust AFR, timing, VE, idle speed and many other parameters to fine tune your engine.
ORIGINAL: Deuce Bigelow
the SERT doesn't "read and adjust the ECM", it is not an add on module like the Fuelpak or PCIII.
If you already have the SERT installed make sure you have the box or dongle (as it's called), if you go to make any changes to it later you will need this. The SERT reads the ECM info and marries itself to the bike it's installed on, if you don't have the dongle for it and want to make changes later you will have to buy a new SERT package and start over.
ORIGINAL: JohnK/Pa
I don't plan on making any immediate changes, but if I do in the future I'd hate to spend another $300+ for a new SERT if it's not necessary. [8D]
E.V.
08-16-2006 10:39 PM
