Best $16 I ever spent
Old 08-13-2012, 08:39 PM
joe kustom13's Avatar
joe kustom13
joe kustom13 is offline
6th Gear
Cool great post thanx
kool thanks for the info. i got the bolts also and the front kit will be doing tommorow, yet got a problem with getting the nuts on the front loose figured out ill have to use a crescent to hold backup on the inner nuts so they will come loose but i got it and will post pics as soon as possible. also i found a kit fro airbaggit for $500. i used one of these on my last build and reversed it for the application worked awesome rode that bike to virginia and back no problems. havent checked out the shotgun yet heard alot about it though looking into it. look up kustom v star 650.
  #92
Old 09-17-2012, 06:54 PM
snksknrZ28's Avatar
snksknrZ28
snksknrZ28 is offline
Whats the best way to adjust the lowering bolts while on the jiffy stand or jack?
  #93
Old 09-17-2012, 07:03 PM
jreichart's Avatar
jreichart
jreichart is offline
I've found it easiest on the jack, though it takes a few tries to get the placement right and still leave access to the adjustment nuts. It can be done on the side stand as well, just much more difficult to fit a wrench under the bike.
  #94
Old 09-17-2012, 07:26 PM
snksknrZ28's Avatar
snksknrZ28
How low can you go with out bottoming out
  #95
Old 09-17-2012, 08:03 PM
jreichart's Avatar
jreichart
Mine is sitting about 2 1/8" lower than stock. Haven't bottomed out yet, I don't think, but I also jacked up the preload a bit to prevent just that. It's a stiff ride for sure, but only bad on those really big pot holes. And chew gum, it helps to keep your teeth from smacking together. Bridge transitions can be pretty harsh too.
  #96
Old 09-17-2012, 08:40 PM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
The lower you go the more preload you need to avoid bottoming out. If you just drop an inch or an maybe one and a quarter inch, and ride solo, you can probably keep the stock preload and it will ride exactly as it does now. If you going for max drop and ride two up, you will need to tighten the preload. That that will stiffen up the ride, but keep you offf the bump stops. For me, I dropped it 1 1/4 inches, and added two extra turns on the shocks. That was more than enough to keep me and the wife off the stops. I recently raised it to a 1 inch total drop because I was scraping the boards a little too often. I was able to take a turn out of the shocks and it seems like a perfect medium for me. No bottoming out, even with the wife on back, great ride for me solo and I really have to lean into the turns to throw sparks. But most people like it lower than that.
My sig pic is 1 1/4 total drop with two turns on the preload.
  #97
Benway's Avatar
Benway
Benway is offline
I rarely notice mine bottoming out (and I've got it as low as the bolts will go), but I'm not a particularly beefy guy either. I could still go a couple inches lower. Shotguns on the list...
Chaffeekid
27
12-01-2021 09:25 PM
soulpatch
06-06-2018 07:16 AM
izhd
05-26-2016 03:37 AM
Domestic Violence
10-24-2009 10:36 AM
mud
06-29-2006 02:11 PM
Quick Reply: Best $16 I ever spent
