Help with fatboy
Help with fatboy
I recently bought an 08 fatboy and haven't had a chance to ride it much. It sounds like it is running on one cylinder and the check engine light will come on. The ethanol gas has been in the tank for awhile, about 1 gal. I put some seafoam gas treatment in the tank, fresh gas, and changed the plugs but the problem is still there. Any suggestions? I am new to this forum so I apologize for asking this question twice.
Did you buy it from a dealer? There might be some warentee things they can do or at least inspect it. If not you could always go to the person you bought it from but that usually never works. There are many many things that could be going on and without specifics on whats going on or what mods have been done to the bike we arnt gonna be of much help
a dead cylinder can be so many things yet just a few basic checks can get it checked for the right direction to go.. ck for fire at each plug wire.. loosen them before you start the bike, then slowly pull the wire off the plug and see if hear a snapping sound on both wires and what cyl makes the least difference with the wire pulled off. if thats good then you have fire. note what cylinder didin't change when you pulled the wire off. now swap plugs and see if the miss moves to the other cyl. if it does, then you know that plug is bad. if that doesn't change, ck the injectors and make sure they are connected all the way. since it is the easiest, you may want to look in and check before you do the plug wire deal. listen for a hissing noise while its running like a vac leak. that info should get ya somewhere if it is actually missing.
