Reshaping or Mod'n A Deluxe Seat?
Old 03-02-2012, 08:18 AM
jakazz's Avatar
jakazz
jakazz is offline
I used a serrated knife, and a grinder, be very careful with the grinder takes alot off real fast, real light touch. Then I kept putting it on the bike got close, took it for a little romp, sanded a little more, through the cover on. centered it couple staple here and there, just to make sure it looked even then finished the stapling. Done.
Granted if you look at the seat in stock form the stitched seam is at the top edge of the sides, now it tucks almost underneath the side. I had my lepera right by its side the whole time checking the profile for reference. Its just as comfortable as the lepera, although thats not saying much after 6-8 hours in the saddle.
Old 03-02-2012, 09:19 AM
SprungDave's Avatar
SprungDave
SprungDave is offline
In the past, I have used an electric knife to remove the larger and some of the detail pieces of foam. The electric knife allows a real soft touch and very thin pieces to remove. Of course if you are heavy-handed or ham-fisted, you can do quite a bit of damage with it too. A random orbital sander makes the final smooth shape of the foam. Wear goggles and at least a bandana. The foam dust gets everywhere. One last suggestion: go to harbor freight and get the electric stapler ($10 on sale). When you are fastening the cover with staples to the seat pan, it makes for quick, smooth work of attaching the fabric to the plastic seat pan.
geneC
12-24-2013 03:00 PM
harleybiker
09-10-2011 06:00 PM
hdviking
10-28-2007 07:20 AM
harleybiker
10-03-2007 10:06 PM
elkhorn
08-24-2007 10:13 AM
Quick Reply: Reshaping or Mod'n A Deluxe Seat?
