Cleaning up my back rim
I need to find something that will clean up the back rim and remove the start of what looks like to be some corrosion or what not. For those of you with Trains, I am speaking not about the black part of the back rim, but the shiny part that doesn't seem to have the luster it once had as new. Anyone have ideas of something strong enough to clean it well but not mess up the finish?
use Shout Triple Acting spray cleaner - buy it a any local market in the laundry section. It does not have teflon in it so you don't have to worry about getting it on you brake pads or rotors. spray it on let it sit wash it off, repeat - use a soft cloth to rub it in. Takes of roadgrime, brake dust, tar, bugs and leaves rims like new. Ride safe and often.
I hope its not, but if its the white, crusty looking spots, it is most likely pitted and will require re-polishing. I had to do this on a buddy's Sportster a few weeks ago. I put his in the lathe and polished the lips, scuffed the black part, and cleared the wheels.
My last bike had the polished aluminum? wheels, and my Deuce had the aluminum rear wheel. I used to use 'Flitz' metal polish to keep them clean and shiny. The first time or two that you do it, it will take a while due to the condition they're in now. After that it's 10 minute job every couple of weeks.
One tube will last forever!
(I've since chromed the rear on my Deuce)
http://www.flitz.com/
I did one side this morning. It turned a piece of cloth totally black. The rim is a bit shinier, but where the oxidation was, is now blackened. I don't want to have to take the rim off to get this done. Can I use any sort of power tool with a brush on it to make it clean faster?
Yep I agree with stlflstf_mike I bought a night train because I didn't want to be cleaning my bike all the time. You are fighting an endless battle with uncoated aluminum. It will constantly be oxidized and you will be cleaning it constantly and it will never look as good as either polished and coated aluminum or chrome so I just gave up. I ride dirty!
