Decel popping on 2012 Fatboy with Rush Slip ons
#43
I also just added rush slip ons to my new 2013 breakout. I have a lot of decel popping. I did not have a torque wrench but righted them down pretty good. Eventually I will add a stealth S&S air cleaner and am thinking screaming eagle tuner as it is very inexpensive (around $295.00 with cables). ****, I am now going to the garage to see if I can tighten the bolts on my mufflers. I read from many that the Rush 1.75s don't cause this problem. Wtf?
#44
There is so much disinformation on this subject.
Read this if you want the straight scoop written by a person who really knows of what he speaks.
http://sales.nightrider.com/2007-and...mance_b_5.html
#45
No efi upgrade required
#46
Thanks for the link Rifleman. I don't know if we all worry more about the gains or the warranty but everyone seems to think an efi mapping is needed for exhaust upgrades. A friend of mine has just purchased a new FB Low with stage one off the showroom floor. Running short shots and a stealth a/c. Harley said they won't add the efi mapping until the bike has done its 1000 mile service. Could this be proof that mapping is not really necessary? I will add my A/C upgrade now with the Rush mufflers already on and run it to see how things go. As I remember 15 years ago, all Harley's with custom pipes had decel popping. We all thought it was cool. Maybe it still is
#47
The 'disinformation' is partly due to the differences between models and configurations, not necessarily due to lack of knowledge.
Some exhaust systems work better when the AFR, sometimes coupled with changes in timing are delivering results (emissions) outside of EPA regulations. They will require remapping to get them to perform to their maximum potential in many cases.
Popping on decel is due to a lean condition (you can't even get everyone to agree on this fact). Emissions have to be increased beyond EPA regs (which any HD dealer following the law will not do) and so tuning and/or an ECM replacement by non-dealer parties is required.
#48
Your bike is running lean right out of the factory. With the new pipes it's even leaner. You need the ECM remapped. Go with the FuelPak, reason being if your gonna upgrade your breather then you can simply reset the mapping yourself with the fuel pak. Also any engine mods you make in the future you can tune the mixture just as easy. The dealer will charge you everytime you make a change unless you swing a deal with them for buying the accessories from them they will remap the ecm for free
#49
#50
-Ryan
